Available - March, 2013. Display - 1080 x 1920 pixels, 5.0 inches, 16M. Internal Memory - 32 GB, 2 GB RAM. Chipset - Huawei K3V2. CPU - Quad-core 1.5 GHz, Cortex-A9. Primary Camera - 13MP. Android OS, v4.1 (Jelly Bean).
مشكلة في فتح الهاتف لا يريد ان يفتح
مرحبا اهلا وسهلا عندما اقوم بضغط علي زر التشغيل من الجانب لا يفتح الهاتف و شعار الشركة يظل موجود ولا يفتح ارجوا ارد
Google translate:
Problem opening the phone. It does not want to open
Hello, welcome. When I press the power button on the side, the phone does not open
The company logo remains there and does not open. Please reply
@kabo75605 this is making the assumption that you have NOT tried to unlock your bootloader or tried to flash some "custom" ROM. If it is just stuck on the boot screen there are a few things you can try:
  1. Long press the Power + Volume Up button to turn off the phone, then restart it.
  2. Secondly, you can try to Boot into Safe Mode.
  3. Press and hold the Power Button.
  4. Release the Power button and hold Volume Down key.
  5. Hold Volume Down until teh lock screen appears. In the left corner on the screen you should see "Safe Mode"
  6. Now let go off the Volume Down key and unlock your phone as usual.
or you can:
  • Press and hold the Power button until the Power off box prompt appears.
  • Touch and hold Power off until the Safe mode prompt appears.
  • To confirm, tap Safe mode. Check on here for the printed and pictorial instructions.
  • Upgrade to the latest firmware update.
  • Wipe the cache partition of the phone.
  • Try to place you phone into Recovery mode. Check on here hoe to do that. In that recovery menu, try the "reboot system now" option
  • Delete all of the data using Hard Reset. (Absolutely the last option)
  • This will of course delete all of your data. Pictures/texts/contacts/password etc. so not something you want to do lightly. It is absolutely the last thing you want to try Huawei Ascend D2 wipe data / factory reset
As always you have to make sure that you back your files up. Any of these Options have the potential to mess with your files. Let's see if this unfreezes your phone.
Translation
@ kabo75605 هذا يفترض أنك لم تحاول فتح أداة تحميل التشغيل الخاصة بك أو حاولت وميض بعض ذاكرة القراءة فقط "المخصصة". إذا كان عالقًا على شاشة التمهيد، فهناك بعض الأشياء التي يمكنك تجربتها:
الضغط لفترة طويلة على زر Power + Volume Up لإيقاف تشغيل الهاتف، ثم إعادة تشغيله.
ثانيا، يمكنك محاولة التمهيد في الوضع الآمن.
اضغط مع الاستمرار على زر الطاقة.
حرر زر الطاقة مع الاستمرار في الضغط على مفتاح خفض مستوى الصوت.
اضغط مع الاستمرار على خفض مستوى الصوت حتى تظهر شاشة القفل. في الزاوية اليسرى من الشاشة سترى "الوضع الآمن"
الآن اترك مفتاح خفض مستوى الصوت وافتح هاتفك كالمعتاد.
أو يمكنك:
اضغط مع الاستمرار على زر الطاقة حتى تظهر مطالبة مربع إيقاف التشغيل.
المس مع الاستمرار إيقاف التشغيل حتى تظهر مطالبة الوضع الآمن.
للتأكيد، اضغط على الوضع الآمن. قم بزيارة هنا للحصول على الإرشادات المطبوعة والمصورة.
الترقية إلى آخر تحديث للبرنامج الثابت.
امسح قسم ذاكرة التخزين المؤقت للهاتف.
حاول وضع هاتفك في وضع الاسترداد. تحقق من هنا للقيام بذلك. في قائمة الاسترداد تلك، جرب خيار "إعادة تشغيل النظام الآن".
احذف جميع البيانات باستخدام "إعادة التعيين الثابت". (الخيار الأخير تماما)
سيؤدي هذا بالطبع إلى حذف جميع بياناتك. الصور/النصوص/جهات الاتصال/كلمة المرور وما إلى ذلك، لذلك ليس شيئًا تريد القيام به باستخفاف. إنه بالتأكيد آخر شيء تريد تجربته Huawei Ascend D2 wipe data / factory reset
كما هو الحال دائمًا، يجب عليك التأكد من عمل نسخة احتياطية من ملفاتك. أي من هذه الخيارات لديه القدرة على العبث بملفاتك. دعونا نرى ما إذا كان هذا يؤدي إلى إلغاء تجميد هاتفك.
Kabo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 177
