Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
Display Assembly: Two T3 screws stripped
I was following the display assembly guide up to about step 29 where we had to remove 4 T3 screws. Two of them got stripped to the point where theres pretty much no screw left just a circle. How should I get these out?
Hi, this is Lore. I’m sorry to hear that you have trouble with removing stripped screws from your MacBook Pro. There are a few methods that you can try to get them out, depending on the tools you have and the level of damage to the screw head. Here are some possible solutions:
  • You can try placing a wide rubber band or a piece of cloth over the screw and use a slightly bigger screwdriver to get more grip and turn the screw. This is a simple and low-risk method that may work for mildly stripped screws. Follow the video in this link: https://www.youtube.com/watch?v=0DuDlSU5...
  • You can use a precision screw extractor set, which is a tool designed to remove damaged screws. You will need to drill a small hole into the screw head and then insert the extractor bit to pull the screw out. This method requires more skill and caution, but it may be more effective for severely stripped screws. You can find this tool online or at a hardware store
  • You can use a mini drill or a Dremel tool with a cutting bit to grind away the screw head until it comes out. This is a very risky and destructive method that may damage the laptop case or other components. You should only attempt this as a last resort, and you should wear protective goggles and gloves. You will also need to replace the screw and the case afterwards
  • Try following the instructions in this video
I hope this helps you with your problem. Please be careful and follow the instructions carefully when you try any of these methods. Good luck!
[deleted] crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 670
