Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
Shutting down while plugged into power supply
Hi. I just got my iPhone XS Max and whenever I plugged it into power supply it charges for some seconds and the next thing me checking it back it’s at switched off. That means it’s automatically switches off itself.
If I then unplugged the charger it will then power on it self. Then when power on itself I later plug it into power supply and continue using it while charging and no problem but if I just drop the phone down for it to charge it will still power off it self again.
The main problem that you faced is while not keypad is locked you can use it for a long time but when you leave the iPhone for something it shuts down. That is the issue that I faced and after hours of research, I found the solution there is a problem with the circuit that helped me in that case you can also try once.
did u changed the circuit? plz help me im facing this issue
Sirojuððin Salau crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 165
