Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
My phone speaker is not working
my phone speaker not working
crwdns2889612:0crwdne2889612:0 10
My phone battery is not charging
My phone blinks
crwdns2933315:013crwdne2933315:0
There are a few things you can try first:
  • Restart your phone. This is often the simplest way to fix minor problems.
  • Check your volume settings. Make sure that your phone's volume is turned up and that you're not in silent mode.
  • Clean the speaker grills. The speaker grills on your phone can get clogged with dirt and dust, which can block the sound. Use a soft brush or cloth to gently clean the speaker grills.
  • Update your phone's software.Sometimes, software updates can fix bugs that cause problems with the speakers.
It's helpful
Here are some quick fixes for a non-working phone speaker:
  • Check the volume: Make sure your phone isn't muted and the volume is turned up.
  • Restart your phone: A simple restart can often resolve software glitches.
  • Clean the speaker grille: Dust or debris can block the speaker. Use a soft brush to clean it gently.
  • Test with different audio sources: Try playing music, videos, or making a call to see if the issue persists across all apps.
If these don't work, the problem might be more serious and require professional repair.
Well check out the following: https://www.youtube.com/watch?v=vAG8B0Dx...
One speker not work
My phone speaker not working
My mobile does not work
Mobile speaker is not working
Update (06/25/24)
My mobile is not working
Hello guys,
my phone doesn't vibrate, how can i solve that issue please.
TECNO CAMON15 premier.
Well Checkout the following video it might help you in fixing the issue:https://www.youtube.com/watch?v=W0-_BKzz...
Check volume levels
Reboot your device
Adjust the app sound settings
Clear the speaker
Charger not save
Speaker not warking
Screen is not touching
asfaw kefyalew crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 2,279
