Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
Trackpad not working, keyboard backlight not working
Hi, I have a MacBook Air 2020 that the trackpad and the keyboard backlight stoped working. I just ordered a trackpad cable because I think the cable I not working, but today I figure out that the keyboard backlight is not working as well.
When this problem started I reset de Pram and SMC but noe of those things worked.
Do you think the MacBook does have an other problema that the trackpad cable?
I think it may well be one of the cables for the keyboard and trackpad. If the cable seemed broken when you ordered the replacement part, then it very well could have caused the keyboard backlight to break too, as they could be shared from the same cable. You might also want to check all other cables to make sure that the keyboard cable is looking fine.
If the replacement cable does not fix these issues, the the problem may well be something else.
Good luck fixing your MacBook Air!
Thank You! does the trackpad cable is the same that the keyboard cable, do you know the name or the part id to order it? I can't find it in the fix page
Hi! i Just replaced the cable, but the trackpad still not working. Today arrived new trackpad, but I think the problem is in the SMC or something related. Do you know which are the best way to find where is the problem? Thank you
Felipe Salas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 80
