Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
I phone xs panicfull i2c0 checkinterrupt error interrupt
I phone xs Restart while pluged lightening cable or earphone in the lock screen .. when i pluged the phone to charger its normaly start charging but when the screen get locked and screen black then in aoutomatic restart. But if i use phone then it charging normaly. Panic log also showen everything.please give me the solution...
Can you currently edit it? This is happening to me now. If you know please tell me.
The problem is that my iPhone XS Max restarts when it's not in use. When I'm using it, or when something like music is playing in the background, it works fine. However, the moment the display is off and nothing is running in the background, it restarts. Another thing I’ve noticed is that it heats up very quickly, even during normal usage.
For context, the battery was recently replaced at an Apple Authorized Service Center, and the battery health is at 100%.
Based on this panic log and your symptoms this sounds like a new charge port assembly is in order. The panic itself refers to ad5860, which is the chip that controls the vibration motor, and signals travel through the charge port assembly. Especially given your other symptoms which seem to revolve around the charge port, I think that's a good first step.
crwdns2886500:0Replace a lightning connector, microphone, and flex cable compatible with the iPhone XS. Fix problems with charging, USB device connectivity, and audio recording. Part #821-01363.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone XS Lightning Connector Assembly
$24.99
Its Sunny 3309 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 3,292
