Interchangeable power boards with BN44-00667A
Anyone can suggest Interchangeable power boards with BN44-00667A?
Also what's generally the probability of interchangeable modules, power, main or T-con boards, in the same TV brand and in other brands? How does it work?
I would like to know which power board is could use instead of a un46fh5005h
@paul80098 what number is the board that is in your TV? Why do you think you need to change it?
@rednci interchanging is not at all common. Just like any other manufacturer, boards are in general designed to fit only the series they were meant for.
Sometimes you can modify things like power-boards to make them but it requires a schematic so you can change the pinouts if needed.
Mainboards and T-con boards generally are not interchangeable. Besides connector issue, most of those also have an EEPROM that is “locked” to the settings for that series.
Besides the board number, give us the model of your TV so we can at least check if there are similar boards that you may use.
UN46EH5000F or UN46EH5050F or UN46EH5300F. I don't know exactly as the back was lost. But all 3 models are very similar. I am trying to buy the cheapest Power Board that MIGHT be compatible, give it a try and if not work, send the TV to a recycling center. Thanks for your help.
@rednci recycling center????? What's wrong with the TV? What are the symptoms. Wait! Don't bin it just yet :-)
@rednci any of these will fit
HG46NA570LBXZA
HG46NA578LBXZA
HG46NA590LBXZA
LH46HDBPLGA/ZA
UN46EH5000 FXZA
UN46EH5300FXZA
Looks like around USD $40 used
Thank you, Oldturkey03, really appreciate.
I found some TVs on marketplace but none with the same power board. What I was hoping for is that some other power board models that are interchangeable (like slightly different [edition/model] ). I am not at the level of chaging pins, but, if I widen my search on ebay for several models of PB, I could find a lower price.
Looking only for mine - BN44-00667A - didn't give results.
Red Nic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 141
