Launch Date : August 29, 2022 (Official), Operating System : Android v12 , Custom UI : Funtouch OS
My phone is switched off and my display not working
And my display out of my phone
Update (12/09/23)
I will repair or not
crwdns2944067:05crwdne2944067:0
My phone screen broken I want to change
Vivid y30 may half screen display problem
My phone's screen is blank and the display can not work.
Does your phone make any sounds or vibration when switching on or off while plugged into a charger. If so you probably do need a new screen the flex cables are very delicate.
Camra was very bed
@kavalisridhar there is a lot that seems to get lost in translation. Give us more descriptive information about what is going on with your phone.
It is entirely possible that it doesn't come on because of the display issue. I would start by replacing the display. That way you have a known-well part and can do any further troubleshooting after that.
Since iFixit does not yet have a guide for this, use the one from here Replacement displays are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Hp tidak bisa di cas
@azlanzaida32473 you are not giving us enough information. you need to consider to letting us know if anything happened to your phone? Did it just stop charging? what have you checked and what have you tried to fix it?
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on i
Display type
What is this, a contest to see who can confound us with the fewest number of words?
You're going to have to give us a lot more information if you really want help.
@dadibrokeit I say @jpakkalkot38682 has won the contest :-)
My answer would be IPS LCD
@oldturkey03 Nice, we have a tie! :D
My phone display is broken
@jassadhillon, what phone do you have? If it's the same y35 as in the original question, then you already have an answer; read @oldturkey03's Most Helpful Answer to find out how to replace the screen.
Kavali Sridhar crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 1,462
