Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
Trackpad works but the top layer has detached
On my Late 2016 MacBook Pro (A1707), the trackpad works but the top layer that is visible, is detached on the right side. Is it possible to fix this without removing the battery?
I’m wondering if could mount some double-sided tape underneath the track pad on the right side, not pretty but might work.
Update (12/06/23)
Hi Dan, thanks! CoconutBattery reports: Full Charge Capacity: 95%; Design Capacity: 49%; Cycle Count: 719; macOS Battery Status: Good
Well how about checking the battery as just based on its age its likely its time for a fresh battery. I would install CoconutBattery and make a fresh Question in Answers so we can check it out together.
I’m going to assume this is the original battery, while Cycle Count: 719 is on the edge, the Design Capacity: 49% tells me this battery is not healthy!
So… if you still want to use this system it makes sense to replace the Touchpad and the battery you’ll easily get a good six more years of use!
Review these guides:
Here’s the needed parts:
crwdns2886500:0Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Pro 15" Retina (Late 2016-2019) Trackpad
$54.99
crwdns2886500:0Replace a 6670 mAh battery compatible with MacBook Pro 15" Retina Late 2016 to 2017 A1707 model laptops. 76 Watt Hours (Wh). 11.4 Volts (V).crwdne2886500:0
MacBook Pro 15" Retina (Late 2016-2017) Battery
$134.99
crwdns2886500:0MacBook Pro 15" Touch Bar Late 2016 Batterycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
MacBook Pro 15" Touch Bar Late 2016 Battery Replacement
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
1 - 3 hours
crwdns2886500:0MacBook Pro 15" Touch Bar Late 2016 Trackpadcrwdne2886500:0
MacBook Pro 15" Touch Bar Late 2016 Trackpad Replacement
crwdns2937801:0crwdne2937801:0
1 hour
I wanted to replace the battery anyway, but not right now. I fixed the trackpad using two small patches of double-sided tape in each corner, which works well. I'll look at it again when I work on the battery. Thank you for the links; very helpful!
@togedo - I understand it’s a bit of change. In the meantime make sure you backup as one day you might not have access until you fix things.
If your set please accept the answer- Thanks!
togedo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 147
