The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
Can cold temperature damage it?
Since there is a special liquid in it, can it be frozen? If so, it won't be damaged? I am afraid, because if i order it, it will be stored in parcel machine, which is located outside where is cold.
@lankerst how cold is cold ;-) ? Excellent Question
No, it won't damage the iOpener. The iOpener is like an icepack/hotpack.
@jri_creator is about right. The iOpener contains Glycerol. So let's say iFixit had the glycerol mixed with water at a common 64/36 or a 2:1 solution, the freezing point will be in the -40 deg C (-40deg F :-) region. Even then it will not freeze but turn into a very thick and viscous liquid. Also, there is minimal expansion only, so the risk of rupturing is low. Check it out.....:-)
Ind. Eng. Chem. 1925, 17, 9, 924
Publication Date:September 1, 1925
https://doi.org/10.1021/ie50189a017
Extreme temperatures can destroy anything I will comment my real answer on this in a moment
Yes most likely but only VERY cold or warm temperatures
LanKerst crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 114
