The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
The proper size is PH0
First get the screw out and take them into a hardware store or electronics parts place and have them get you placements and then reinstall using the proper sized screwdriver
Try soldering iron and twist with your screw driver
KingCool crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 427
