Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Touch ID works but power button doesn't
My power switch doesn't work even though Touch ID continue to work properly.
It doesn't create too many problems in everyday use — I didn't even spot it for several months — but I cannot, for example, do SMC reset or force shutdown. Which doesn't seem too important until you have to disassemble your Mac to shut it down by disconnecting battery :)
Is it possible at all to replace/fix only power switch functionality without replacing a logic board?
Well… This is not a simple fix! If you are not using TouchID then you could just swap out the button assembly. But you must fully disable TouchID services and any use of TouchID, otherwise you won’t have access to that service or even your systems files if you encrypted the drive. MacBook Pro 15" Retina (Late 2016-2019) Power Button
The other way is to carefully replace the blister button part if that is the failure. Here’s an image of the part so you can see the switch.
You will need a someone with the needed soldering gear and skills to desolder the button and replace it.
You might find a piece of metal was placed where the dome of the blister switch hits within the uppercase has slipped off or maybe it’s needed here to offer a better surface. That assumes the buttons switch it’s self is working properly.
crwdns2886500:0Replace the sapphire faced Touch ID equipped power button assembly.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$34.99
Axel Mort crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 182
