It’s giving error -1
I have iPhone SE 3rd gen its giving error on 68 percent
Error code is -1
Is this a base band problem or where should I check
Error code is -1
Not quite sure but I did some looking and yeah it’s prob the base band. I found this post from 2017. “ITunes error -1 is baseband firmware failure to load. It is the eeprom ic failing to communicate with the modem hardware issue 100% either cracked ball on the modem data line or damaged eeprom. You will have to take it to a capable technician with eeprom programming equipment.“
Thanks for this information
I’m a technician myself but don’t have eep rom programmer but I’ll check for line breaks
crwdns2942667:0crwdne2942667:0 102
