crwdns2918566:0crwdne2918566:0
crwdns2937205:0crwdne2937205:0
crwdns2949563:0crwdne2949563:0
crwdns2949565:0crwdne2949565:0
crwdns2949613:0crwdne2949613:0
crwdns2949561:0crwdne2949561:0
crwdns2935075:0crwdne2935075:0
crwdns2937219:0crwdne2937219:0
crwdns2931767:0crwdne2931767:0
crwdns2937209:0crwdne2937209:0
crwdns2916546:0crwdne2916546:0
crwdns2937207:0crwdne2937207:0
crwdns2952471:0crwdne2952471:0
crwdns2952473:0crwdne2952473:0
crwdns2958714:0crwdne2958714:0
crwdns2952475:0crwdne2952475:0
Right to Repair
crwdns2937217:0crwdne2937217:0
crwdns2918526:0crwdne2918526:0
crwdns2937227:0crwdne2937227:0
crwdns2937229:0crwdne2937229:0
crwdns2937231:0crwdne2937231:0
crwdns2949655:0crwdne2949655:0
crwdns2949657:0crwdne2949657:0
Texas Instruments TI-84 Plus calculator support.
Leigha Cox @leighacox
crwdns2934065:0crwdne2934065:0: 1
crwdns2955602:0crwdne2955602:0: Huk 14, 2023
When I turn on my calculator I none of the buttons I press work, the cursor is blinking on the screen but I can’t even turn the calculator off. I tried removing the batteries and charging it and that didn’t work.
jayeff @jayeff
crwdns2934065:0crwdne2934065:0: 551crwdns2936485:0crwdne2936485:0
11
425
1,6crwdns2936485:0crwdne2936485:0
Hi @leighacox
Try the following and check if it resolves the problem.
Remove the batteries and the back up battery from the calculator and then press and hold the ON button for a full 20 seconds and then release it.
Note: Remember the way that the back up battery was installed (+ve on top as seen on the battery itself) so that you reinsert it the correct way.
Reverse the procedure to reassemble the calculator and check if it turns on and works OK.
Here's the ifixit TI-84 Plus Disassembly guide that may help. You don't have to go past Step.5
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 1,738
