Frigidair combo dryer starts and stops after a few seconds.
Model FLCE7522AW frigidair combo dryer starts and stops after a few seconds without any sounds or beeps. What can it be? Washer works perfectly fine.
@krystalcol57696 at what point does it turn back on? Immediately or do you have to wait a while? What have you checked? Could be a failed thermostat etc.
It does not turn back on once it has shut off, only turns back on if I press the start button again and then shuts down again after a few seconds.
Mine does the same thing. Is there a picture or a diagram of where the thermostat and fuses would be located?
Mine does the same thing. Is there a picture or diagram of where to find the thermostat and fuses? Model FLCE7522AW3
Most dryers would have a similar schematic. There are thermal cutouts in a dryer but no fuses. See my above comment.
Is there any sign of heating? It could be a high limit thermo. It could be a problem with the heating coils.
No :-( since it stops just seconds after starting, there is no sign of heat.
Krystal Colon Maldonado crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 411
