The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Nintendo New 3ds xl Permanent blue light, black screen
I bought a faulty new 3ds xl, at this instance the problem was that the console doesn't turn on due the battery.
Everything look fine, shell, screens, charger, digitalizer...
After change the battery for a new one, the 3ds was able to power on, but just a blue light with black screen (The blue light won't come off until I press the power button for 5 seconds).
I had a look into the SD card, and it looks like there isn't any homebrew in the console.
After that I saw a few tutorials talking about a problem with the WI-FI module, I had follow all the steps but without luck (I have to mention that all the components look in a great status, in my opinion, I think that I was the first one that opened the console).
I have tried to go to the Update Screen Pressing and hold L + R + (dpad) UP + A + Power, nothing happen.
Few more tries, I decide to remove flex by flex to check if I got any other kind of light, but having always the same result, black screen with permanent blue light. Also, I tried to power on the console without any more components that the Motherboard and the module for the battery, with the same result.
For last, I saw a few videos using the ntrboot method (flashcard) to try to bring it back the system, but, when I press the button combination (X + Select + Start + Magnet(for sleep mode) + Power) and I release the magnet, the 3ds just turn off. With this method is the only moment when the console do anything different, but I wasn't able to go far away.
I'm very newbie in this area, and not sure what else I could check. Do you have any ideas?
Thanks in advance!
Unfortunately the problems of the "blod" are not visible(or very rarely), so you need spare part and testing them one after the other there is no other solution. because the "blod" can come from the wifi card, a ribbon cable damaged, or one of the two screens (on the old 3ds the touch screen and the camera also can cause the problem and maybe can still be part of it). Almost all components are a suspect. So unfortunately no one can tell you precisely which component is the problem
ModraSam crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,178
