Hi @leellenwilliams,
What is the model number of the washer?
Also does it only leak during the fill process of the wash (and rinse cycle?) or also during the wash cycle (agitate) itself?
If only during the fill process are you using both hot and cold water or only one of the two?
If it is only occurs during the fill process (both wash and rinse) it may be coming from the water inlet solenoid valves' connections (hot or cold?).
If it occurs during the wash (agitate) cycle as well it could be a leak from where the water level pressure hose connects to the bottom of the tub. This hose goes up and connects to the water level pressure switch in the control panel
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
