Disk read error occurred
My laptop has ran into a error where the disk can't be read, I pressed f2 and I don't know how to reset/reboot it, non of the "Boot priority orders". Help me please
First of all - can you see the hard drive in the BIOS? If 'yes' then try the Windows recovery environment:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
  1. Turn on your PC.
  2. As soon as the Windows logo appears on your screen, press the power button to turn off computer.
  3. Repeat steps 1 or 2 two more times.
After the third interruption, Windows 10 will open into the Advanced Start-up environment
·         While in the Advanced start-up environment, use the following steps to use Start-up Repair:
  1. Select Troubleshoot button.
  2. Select Advanced options button.
  3. Select the “Start-up Repair” button.
  4. Select your account.
  5. Type your account password.
  6. Click the Continue button.
You could also try running 'chkdsk' command look in advanced options
From CMD Prompt
 Run following:
 Chkdsk /F
If that doesn't work you may need to run a drive sector recovery software.
My favourite one is below but there are others
RJOE 133 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 103
