The Airpods Pro 2 is a revision to the original Airpods Pro. Released on September 7th, they allowed better audio, two times more noise cancelling, and volume controls. It also boasts a larger battery, and a speaker on the case to make finding them easier.
Charging case problem charging problem
Charging case charging problem
crwdns2889612:0crwdne2889612:0 12
Yes my airpods don't connect to charger
crwdns2933315:06crwdne2933315:0
When I plug a charger in charging case it cannot start charging then I put it tightly then it starts charging but after a night I put it full but it's battery is down
Uau, that worked for me!!! Thanks bro
What is wrong with your charging case? If you bought your airpods recently in the past 30 days from apple, 90 days from costco, or have apple care+, you can get a replacement or refund. If you have any other info about your problem, please let us know. Is it not charging? Is it not pairing? Is it not playing sounds or popping up on find my?
It doesn't charge the hearing aid box
Charging problem
When I plug in my AirPods to charge, they do charge; however, as soon as I disconnect them from the power source, the charge becomes completely ineffective—rendering my AirPods unusable. They only function when they are actively plugged in and charging.
Mine seem to do the same thing. And after they charge for about 30 minutes, they start beeping and when I take them off the charger, they are very, very warm.
Not charging airpod
Update (05/18/26)
Not airpod charging
Not airpod charging
Badal Kushwaha crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 2,475
