Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
Power steering not working
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
Mohd mufeel crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 513
