The Bose QuietComfort 35 II (Model Number: 789564-0020) are Bluetooth, noise cancelling headphones designed by Bose. The device comes with a USB charger and a Headphone jack cord, and is compatible with IOS and Android Bluetooth Devices.
Charging problem - replace Micro-USB connector?
I can't charge the headphones. Is it possible to replace the Micro-USB connection?
I also have this issue.
With the charger disconnected I see a blue led light of the pairing that is always on.
When I connected the charger to the micro USB connector a red led light starts flashing and the blue led light continues to be on.
I already replaced the battery. I was now thinking on replacing the micro USB connector. Do you have any other idea's?
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
If you have 2 LEDs, the blue one is telling you it is on and paired. The blinking red one is telling you it is charging. If there was a problem with the connector, the red LED would not be flashing when you plug it in. However, if it is "flashing' (fast blinking) it may be telling you there is a problem with the battery or something internal.
Why do you think it is the connector? There are a number of other possibilities including the charger and the battery.
Post any symptoms you have experienced in the past.
I have several chargers.
The problem occurred suddenly without deteriorating battery before.
I can visually see the damaged connector.
Johan Varland crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 622
