Bright nets are coming down
@sansuiledtv we need to know your exact model and how low the brightness is. With the TV turned on, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 125
Sound in on but tv picture is not yet
crwdns2934271:0crwdnd2934271:0 Priytama vekde crwdne2934271:0
