Garbled sound from both speakers.
After a change if elevation (flying or coming down from altitudes >4K ft), the sound coming out of the speakers is garbled. Blue tooth audio devices work fine. I have been told this is a fault of a pressure differential between the inside the case & the atmospheric pressure. Is their a fix for this?
Hi @brucebeauchamp.
Are you using the phone as a phone i.e. for calls in loudspeaker mode or using it to listen to music etc when flying?
If just to listen to music, try removing the SIM card tray from the phone and check the sound quality.
Doing this should equalize the pressure between the inside and the outside of the phone.
If used for calls then doing this (if it works) obviously won't work.
