The Acer Aspire 4520-5464 can be identified by its model number: LX.AJN0X.010. It was released in October of 2007, and came equipped with an AMD dual-core processor and a 14.1” screen.
Why is my laptop shut down suddenly?
my laptop shut down suddenly and randomly sometimes when started other times on the middle of doing some things
Possible solutions
  • Run memory test
To launch the Windows Memory Diagnostic tool, open the Start menu, type "Windows Memory Diagnostic", and press Enter. You can also press Windows Key+R, type "mdsched.exe" into the Run dialog that appears, and press Enter.
  • Corrupted Drivers
If the problem doesn't happen while in the BIOS settings screen (usually pressing the F2 key after pressing the power button) I would suspect a corrupted driver. First of all see if any drivers are corrupted by checking in the Device Manger. I would start with the Bluetooth. Just uninstall but don't delete the drivers and let Windows reinstall by clicking on Action > Scan for Hardware changes up in the menu.
  • Defective Easily Removeable Hardware Components
If that doesn't work hopefully it is just an easily removeable hardware component with an intermittant failure. Try removing one at a time and testing each time. I would start with the RAM. For the RAM remove modules (usually there are two) one at a time and also try in each individual ones in each slot. Then Bluetooth, Wi-Fi, etc. Even an intermittantly defective hard drive could cause the problem.
The IFIXIT Repairs Guides will help with disassembling. Click on the blue text below.
Acer Aspire 4520-5464 Repair Guides
Let us know how it goes.
Ras Taddese crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 132
