The second generation Integra was introduced in April 1989 and in this generation, one of the first VTEC engines ever manufactured by Honda was installed in a JDM Integra DA series.
I have no spark and no fuel pump prime
Car had bad wiring before and figuring it all out. Main relay was tested= good, fuses were tested= good, fuel pump was tested=good, the distributor is brand new along with the spark plugs and wires. Grounds are good to the battery terminal/transmission , thermostat housing, and valve cover. Car dash lights come on and car cranks. Check engine light stays on, I get no codes thrown when tried to flash for codes.
Would that be the same for a 93? Sorry just making sure
@oniichanz
Yes is is for years 1990-1993
Hi @oniichanz
Here are some images from the 1990 Acura Integra repair manual showing the ignition circuit and the fuel pump circuit, that may help.
(click on image)
Onii Chanz crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 244
