Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
speakers (both)- hardware not working- iPhone 12 mini
Both speakers (and calls obviously)... hardware not working at all on iphone 12 mini. Used phone looks-as new, 99% battery health, with no physical or water damage etc. Made the mistake of buying (in person) used without even considering this kind of hardware/speaker issue before handing over $. Screwed up scammer/seller, oh well, another "cheap life lesson" in the grand scheme of things.
Tried resets including full factory reset, ios update, and any/all relevant settings adjustments etc.
Tested with diagnostic app such as phonedoctor pro which also shows both as failing/hardware issues.
Since the speakers are physically located in different locations of the phone and not (likely/seemingly in my perspective) related to one single loose connector or broken single piece of hardware - what are my chances of being able to fix it as an experienced DIY parts swapper?..
ANY input, experiences, anecdotes or specific advice would be greatly appreciated! Anywhere to look once I open it up, and/or known failed components that could cause all this? Once I solder in the new "loud speaker" with the regular one happen to come back to life. Should I expect to replace both. Thanks in advance!
Note; the iphone 12 speaker recall/campaign does not apply to the 12 mini. Note: either way, this phone is over a year old since first sold so even if it were a 12 not mini, it wouldn't have qualified anyway. I'm looking for repair help not advice to send it in etc.
I would expect to replace both speakers. Just be careful and take your time. Use a hair dryer or heat gun to heat up the adhesive around the screen, use some isopropyl alcohol, a suction cup, guitar picks, and with a little patience, that screen will come off.
You could use the anti-clamp which you can order here: Clampy - Anti-Clamp
Or you could just buy the regular suction cup: Suction Handle
crwdns2886500:045 mm diameter suction cup is a necessary tool for opening iPhones, tablets, and other devices.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Suction Handle
$2.99
crwdns2886500:0Suction cup pliers for easier phone repair and screen removal, powered by hands-free force application.crwdne2886500:0
Clampy - Anti-Clamp
$24.95
albert einsteen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 327
