A samsung laptop released in 2016, identified by Model Code: NP740U5M - X01US
cover (lid) part specifications
So i recently purchased this model used, and ilove it. one issue is that the previous owner replaced the battery at some point and when they did they stripped a couple of screws that hold down the lower case (lid) to the laptop. im struggling finding out what the screw specifications are to find a replacement screw and .......grommit? nut? whatever it plugs into. do you possibly know where i can find this info or replacement?
Update (10/02/23)
@karatemast40262 you are referring to a NP740U5M - X01US right? Can you post some pictures of what you are looking at? That way we can see what you see and hopefully find what you need. Adding images to an existing question
[image|3091394][image|3091395]
The case isnt damaged at all, but i wanna get this fixed so the case doesnt keep popping out like that. I've already pulled the entire case off and it went back together fine.
Hi @karatemast40262
If you don't get a better answer and maybe it's a bit expensive for just a couple of screws, but here's a supplier of a screw kit for the model. The required screws should be in the kit.
crwdns2947821:0crwdne2947821:0
karatemaster161988@yahoo.com crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 110
