Kodak easyshare zd710 battery issue
So today I got a Kodak easyshare ZD710
and it's got a battery issue.
Everytime I insert new batteries the camera thinks the batteries are drained!
Has someone got an idea to fix this?
Update (10/01/23)
Update 1 :it sometimes happens when I insert/reinsert batteries
Update (10/01/23)
It's not from a store btw
Update (10/01/23)
It works but it might happen again when I reinsert batteries
I've got a similar issue with my Z712IS. When it was new, I could change the battery and the camera would retain the clock for a minute or two while changing it.
Today, even if I rapidly swap the battery in 1-2 seconds, the camera will lose its time/date settings.
The official word is that this shouldn't happen - that the camera has capacitors that will retain the time for a short time while the battery is removed. If that's so, then the caps have died, but I have no clue how/if they can be replaced.
I think it is more likely that there is an internal battery (or maybe a supercap) designed to run the clock independent of the battery pack, and it needs to be replaced. But without access to any service manual to teardown document, I can't prove that.
Update: I found the teardown for the Z650, which shows what appears to be an internal battery: Kodak Easyshare z650 Teardown. So maybe there is one in a Z712IS or a Z710 as well.
If you just got to today, I would return it and get an exchange. Take your batteries with you and install them in the store to make sure they work.
This would work out but it's not from a store or something
Pawel C crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 795
