The Galaxy A20s is a midrange Android smartphone released by Samsung in September 2019. Identifiable by model numbers SM-A2070, SM-A207F/DS, and SM-A207M/DS.
My phone has stopped vibrating
My phone suddenly stopped vibrating even when it's set on vibrate mode
Why My phone vibration is not working?
Why my phone is slow?
I want to Solution
Please you help me
@razuahmed you need to help us to help you. What make and model is your phone? What have you checked? what have you tried to fix this? Did anything happen to your phone or did this just start all of a sudden? You need to give us more details if you are seriously looking for people to help you with this.
I’m sorry to hear that your Samsung Galaxy A20 suddenly stopped vibrating even when it’s set on vibrate mode. This can be a frustrating problem, especially if you rely on vibration to alert you of important calls and notifications. There are some possible solutions that you can try to fix this issue. Here are some of them:
  • Restart your phone. This is a simple but effective way to solve many minor problems on your phone. Press and hold the power button and select Restart. Wait for your phone to reboot and then check if vibration is working.
  • Check your vibration settings. Your phone allows you to manage vibration for calls, touch interactions, gestures, and more individually. You can go through all these settings on your phone to ensure that vibration isn’t disabled for any of them. To do so, go to Settings > Sounds and vibration. Enable the toggle for Vibrate while ringing. Then, go to System sound/Vibration control and enable the required toggles1.
  • Check your accessibility settings. Apart from the sound settings, you’ll also need to check the accessibility menu on your phone to see if the vibration is disabled from there. To do so, go to Settings > Accessibility > Interaction controls > Vibration & haptic strength. Ensure that your preferred vibration settings are enabled2.
  • Modify your vibration intensity. If your phone is failing to vibrate despite enabling all the right settings, then it’s possible that the set vibration intensity is too low. You can change that by going to Settings > Sounds and vibration > Vibration intensity. Use the sliders to increase vibration intensity for Incoming calls, Notifications, and Touch interaction2.
  • Test your vibration motor. If your phone is still not vibrating at this point, then the issue could be hardware-related. If the vibration motor on your phone has stopped working, then your phone will fail to vibrate no matter what you do. To eliminate this possibility, you’ll need to test your phone’s vibration motor by accessing the secret service menu. To do so, open up the dialer app on your phone and dial #0#. Then, tap on the Vibration tile, and your phone should start vibrating immediately234.
If none of these solutions work for you, you may need to contact Samsung or your service provider for further assistance or repair. You can also find more information and troubleshooting tips on how to fix vibration issues on your Samsung Galaxy A20 here.
I hope this helps you fix your vibration problem on your Samsung Galaxy A20. Have a nice day! 😊
Dude. Did you really just use AI to answer this question?
@havynk yes, they did. We had us an offline discussion when this happened :-)
Walombe Sahilu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,202
