A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
Digitizer replacement but middle portion is unresponsive
I replaced the broken digitizer on my switch lite which was yellow with a grey one since I reshelled it as well and the new grey one works only around the perimeter but not in the middle for some reason I've read that the V1 V2 switches have different versions of digitizers and that causes this issue if you install the incorrect version but nothing on the lite version is it the same thing where each color is it's own version of the digitizer and it can't be changed to another color?
@diana_knows no it's not. The color differences do not relate in anyway to the digitizer. You may have gotten a bad digitizer. I would replace it once more. See if the seller can exchange that digitizer for a working one for you. Otherwise the issue could be the connector or the cable. Check for any tears as well as bend or corroded pins
Diana crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 120
