The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Fingerprint sensor not showing on my phone
I can't find fingerprint sensor on my phone
crwdns2889612:0crwdne2889612:0 28
Finger lock show
My phone finger lock not show
What is the problem
@kokokhan have you tried the solutions in the original answer? What did you try?
Infinix hot 10i ka fingerprint is not working
@emperorvibez first try to reboot your Infinix to check if your fingerprint sensor is working. IF that does not work you want to check your and update your software. Go to Settings==>About Phone==>System Update and let your phone check for any updates. If there are any, those should show up as Download Update. Use those to download and update your Infinix.
You can still clear your cache and other thing if the above did not work. Check sites like this one for how to clear your caches etc.
If none of that worked, you may have an actual hardware issue, like a failed fingerprint sensor. Since iFixit does not yet have a guide for that, try something like this video It is not the identical model but it will work for yours as well.
A replacement sensor is readily available at many online stores. Purchase one from a vendor to your liking, just make sure you purchase a fingerprint sensor for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
why my Fingerprint is not working on my phone
@mikepaul27121 could be a failed sensor or issues with the software. Did you check the things I’ve mentioned in my answer
My fingerprint is not working on my phone
Fingarprint not showing problam please solve me.problam
@yusufbhati have you tried what was suggest in the original answer?
  1. Navigate to Settings.
  2. Look up "System" using the search box and click on it.
  3. Choose Reset options.
  4. Reset Bluetooth, Wi-Fi, and mobile devices > Reset settings.
Setelah di apdet finger frin
Tak ber fungsi
I have infinix note 10 pro mobile and its fingerprint is not working
Not working sensor infinix hot 30i phone
Emperor Vibez crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 86
crwdns2936753:030crwdne2936753:0 315
crwdns2942667:0crwdne2942667:0 11,959
