2010 Automatic Shifter Solenoid won’t open…stuck in Park
I recently had to charge my battery on my 2010 GT Convertible…done it many times. When done, I found it interesting that the dome lights didn’t come on when I opened the door, but the window electronically shifted down, so I knew there was power. The car started normally, but I was getting all sorts of caution lights…Advance Trac, TPS, others. But more disturbing, when I went to shift to drive, it won’t come out of PARK. The solenoid won’t open to allow shifting.
Any hints on how I can at least get it to shift so I can drive to Dealer?
Thanks in advance
Hi Casey,
To my knowledge, all cars with an automatic transmission that features a shift lock also come with an override for that lock. In your case it can be found on page 203 of your owners manual.
2010 Ford Mustang Owner's Manual
So what I ended up doing was disconnecting the battery all together for a day or so. Then when I hooked it back up, all was well. Taking power away completely reset the electronics. Just lucky...
I don't know if you're having the same issue I did, but in the shifter, if you actually take it apart, there's a little tiny solenoid. You can actually just break it and bypass it, but of course you can then shift the car whether it has a key in it or not and that can kind of be dangerous but it does solve the problem without you having to go to a mechanic or something and that's something that does fail often.
CASEY HUGHSON crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 369
