The Samsung Galaxy A54 is a mid-range smartphone that was announced on March 15, 2023 and was released and available on March 24, 2023.
How to replace the cover over my camera lenses that cracked
I dropped my phone and the plastic or glass covering over top of the 3 camera lenses in the back of the phone cracked. Can that be replaced?
Hi Judi,
Yes, indeed the lens covers can be replaced on your phone; they are available separately from the rear cover. Here's an example I ran across that should work.
Rear Back Camera Glass Lens Replacement For Samsung Galaxy A54 5g A546 Sm-a546v Sm-a546u With Adhesive Sticker - Mobile Phone Housings & Frames - AliExpress
With these the best bet is to remove the rear cover of the phone then clean out all the old glass from the original lens covers. Get the glue off with some isopropyl alcohol and stick the new covers on.
Alternatively if you wanted to spend a few more bucks you could just replace the whole rear cover as one piece; I found one for about $9 USD. You have to remove the rear cover in either case; this way you can just pop the new on one and you're done.
NEW Housing Cover For Samsung Galaxy A54 5G Glass Battery Back Cover Rear Door
Be sure and check any parts you buy against the actual model number of your phone; I see both Galaxy A54 and A54 5G being mentioned, but I can't tell if those are the same phone or not.
Anyway, I found a guide that may help get the rear cover off; it's actually for battery replacement but if you just follow the first step that'll get the rear cover off, which is all you need.
Manuals / Samsung Galaxy A54 5G / Battery
Good luck; let us know if you need any more information or assistance.
The glass is broken, camera is fine
@carol21531 So you have the same problem as the original poster, is that right? If so, then the answer for you is exactly the same as my original answer.
Rear camera foot gaya hai
Google translation of Hindi text:
rear camera is broken
We will need to know more about what's going on with your phone in order to help. This particular question was about the glass over the camera lens; is that what is broken on your phone, or is the camera itself not working?
मदद के लिए हमें आपके फ़ोन पर क्या हो रहा है, इसके बारे में और अधिक जानने की आवश्यकता होगी। यह विशेष प्रश्न कैमरे के लेंस के ऊपर लगे ग्लास के बारे में था; क्या आपके फ़ोन में कुछ टूट गया है, या कैमरा ही काम नहीं कर रहा है?
No actual glass is broken anywhere. THE BACK PHONE COVER has bubbled out along the 2 long sides and is not making contact anywhere. Will this back release completely and then be able to reattach with new glue?
It's preferred you don't include contact information in your questions. First, it opens you up to spam, and second, it takes the discussion away from the site, meaning the rest of us can't benefit from whatever you may learn.
@kaykayholmes, I would say yes, you can almost certainly reglue the rear cover if it's coming off. However, be aware that those parts don't usually come off on their own; there's a reason that's happening that you'll want to address.
The most common reason for the back coming of on its own would be due to a swelling battery pushing it out from the inside. So yes, you'll want to remove the back, but once it's off, check the battery carefully. It should NOT be pillowy or soft anywhere; the outer wrap should be solidly against the flat sides of the battery. If it's puffy at all it needs to be replaced, as it will only get worse; theoretically it could eventually result in the battery catching on fire so it's vital you stop using that battery immediately.
Before you start, order up a sheet of precut adhesive for the rear cover; they're available everywhere, including sites like eBay, Amazon and AliExpress.
Here's a guide showing exactly how to remove and replace the rear cover courtesy of the French site SOSav.
Galaxy A54 Rear Window Repair - Free Guide - SOSav.fr
As you might guess, the site is in French, but if you use it with a browser that does translation like Google Chrome, it is quite usable and their guides are well written and complete.
Judi crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 7,175
