Model A1993. 2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
No signs of life
Hello all, I purchased a faulty Mac mini and am currently working on a diagnosis and just had a few questions. Firstly, if the ram is faulty would the machine show a white light and beep like previous models of Mac mini. Also, is there a way to know for sure if it’s a logic board or a power supply?
Thank all :)
I left it plugged in for a while and came back to a flashing white light on the front in the following sequence: 3 short pulses, 3 long pulses, 3 short pulses
As far as I am aware these machines do beep with faulty RAM. Though I admittedly don’t have personal experience with these specific power supplies or logic boards I think it should be possible to test the voltage if you can find a pin out and test the PSU with a multimeter.
crwdns2944067:09crwdne2944067:0:
To add to what @thequacker Here's the Tone codes (Beep) If your Mac beeps during startup and heres the White LED code Mac mini power LED indicates the computer's status
Thanks for this, I have attempted to plug it into another mac using a usb-c to usb-c cable however it immediately appears to lose power. Would this point toward a faulty power supply? Thanks
@owenmason87347 - I would start there!
Hi, sorry for the delay was waiting for the part. I have now fitted a new power supply. It is no longer immediately losing power but will only show a blinking white light (in sos pattern) and will not show up in apple configurator when plugged in. Could this be a firmware issue? Thanks :)
@owenmason87347 - Apple Configurator is only useful in T2 based and M Series systems. So that won’t help you in this Mac Mini system.
Let’s give this a try remove the RAM and disconnect the drive and try to start the system again did that work?
crwdns2934275:04crwdne2934275:0
Owen Mason crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 310
