Kia introduced the second generation Sedona to the North American market at the February 2005 Chicago Auto Show for model year 2006 offering a single engine/transmission choice.
Engine overheats but no sign of leaks
No leaks but no sign of over heat and the water inside the radiator bubbles white
I would hazard a guess here based on the limited information you are giving. Sounds like a head gasket failure into the water jacket that is allowing compression loss into the cooling system.... bubbles. If bubbling increases with RPM... that is a dead give away. Sounds expensive if you aren't prepared to DIY. Oh and don't use a lighter to peer into the radiator the lighter than water fuel will rise to the top tank.
Wahlter crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 260
