The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Why my switch has a black screen but sounds?
Hi guys. I need help my nintendo switch boots up normally and shows signal from the dock but the screen is on it is backlit but it doesn't show any image plus the digitizer works because if i click something it makes sound. can you help me? It started doing this when I tried to fix the front frame and when I put it back this happened. Thank you in advance for your reply.
crwdns2944067:05crwdne2944067:0
My switch is on but the screen is just black and no light is coming from it can you help
@jacobmunguia has any repairs been done to it or has it been opened
Mine is the same thing
what help is this to me
Turns out while i was tearing down my nintendo switch for a front shell swap i broke the digitizer connector on the motherboard and at the and i decided to resort to a soldering professional to get It replaced
the digitiser connector is on the game card reader and wouldnt cause no image
Any idea to résolve issue?
There are two connectors for the screen, one is for the digitizer and the other is for the LCD. It sounds like you got the digitizer plugged back in correctly, but I'm guessing the LCD flex cable isn't seated quite right. Here's the cable you should be checking.
You'll need to open the Switch back up and check that connector. There are two little tabs on either side that should both be butted up against the connector itself; if they're uneven or not inserted all the way you could well have video image problems.
Take a look at that and let us know what you find.
Update (08/31/23)
There is a second LCD connector that could conceivably be causing problems if it isn't in all the way.
If you hold a flashlight up to the screen, can you see any image? If so, that would indicate that the backlight is out for some reason. On smartphones it wasn't unusual to blow the backlight circuit either on the LCD or on the logic board if you plugged and unplugged it with the battery connected, but as far as I know that hasn't been a big issue with the Switch so far.
Hi thanks for responding so quickly I've already checked that connector I've reattached and unplugged it at least four times but strangely it always doesn't go the contacts seem fine because even though I haven't used a microscope. Because it's my first time repairing, I don't have access to this tool. what else do you think it could be?
Still nothing of i hold a flashlight nothing dunno what's appening🤷
Did you ever figure out how what was wrong with it? Mines doing the same.
Have same issue .... But m'y switch v2 sometimes display ok for some seconds and after blackscreen , blacklight ok , sound ok
Pierfranco crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 135
crwdns2936753:030crwdne2936753:0 570
crwdns2942667:0crwdne2942667:0 19,944
