How do I take off my phones broken screen.
How do I remove a broken screen from my phone
Hi Corey,
The normal/official/accepted way of replacing the screen on your phone is to replace the complete screen/frame assembly as one piece. That eliminates any issues with separating the old screen from the frame and resecuring the new screen to the frame since the frame comes with the screen already mounted on it. The gist of it is you have to gut the old phone and transfer basically everything to the new screen.
Here's an example of a repair guide showing you how to replace the screen/frame assembly.
Samsung Galaxy A23 5G screen replacement - repair guide
However, it is also possible to replace just the display without the frame; it took quite a bit more searching to find a YouTube video showing how to do that replacement. A little less work with regard to transferring parts, but you do have to glue the replacement screen back on the frame securely.
Fix Your Destroyed Samsung Galaxy A23 - LCD Combo Replacement - YouTube
I would personally recommend the first method as that's the preferred way to do it, but you can save a couple of bucks (very little, really) by buying just the screen without the frame.
Hopefully that gives you all the information you need; let us know if you have any more questions.
are there any components besides the battery that should (due to likely failing ) be replaced at the same time so i dont have to do this again when when it happens. A23 and\or A13 5G
@christophe11296 Not that I can think of. The battery is the only part that "wears out" so to speak, and the screen is normally only replaced when it's damaged, so yes, now would be a good time to swap in a new battery, but there's really nothing else that would need attention.
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 3,402
