The JBL Tune 510BT headphones are lightweight, cordless headphones. They have earmuffs that swivel in and out for storage and can be extended or shortened depending on the user's preference.
Can I fix this Detached part of my headphones
As you can see my headphone can stay on my ears because of this part .
I tried to glue it with hot glue but but it does not stay in place and ends up detaching . I would like to know if there is a way to fix it and how or if it is simply impossible.
yo casualmente tengo el mismo problema, en una caida se desprendio el enganche que unia al auricular, por el momento no encontre solucion
I have the same problem, I think the only solution is to buy new ones though
If you want it easy then set it where you want it to be and glue it with super glue mine háve been like this for a year and there are working great
Here is a easy solution.
Get a small plastic ring, (I got mine from a pen) cut it down the middle and make sure it fits, if it dosnt sand it down, then put glue it on and seal the ring by heating up a needle or small metal object and basicly welding it together.
Nems crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 270
