Power supply fuse keeps blowing
Hello,
We have a 4 year old UN55MU6290 Samsung TV. Last week while it was on it made a pop sound and turn off. Once I had a bit of time over the weekend I opened it up to have a look.
First I did a visual inspection and didn’t find any component damaged or burnt (neither on the power supply nor on the main board). I took a multimeter and first thing I checked the fuse: open circuite.
I thought easy enough… I ordered a package of matching fuses (T5AH250V). The fuses arrived today. I replaced the fuse reassembled the TV plugged it in and… it didn’t work.
I open up the TV again checked again the fuse I had just installed and… it had blown.
I then replaced the fuse again. This time I did not reconnect the neither main board nor the backlight to power supply board and I powered it up with the TV open.
The fuse blow again as soon as I plugged in the power. So for sure there is something wrong with the power supply board. It burns the fuse as soon as powered up even if disconnected from the rest of the TV.
Now I can order a new power supply board (BN44-00807K) for cheap. The question now is how can I check that there is nothing wrong with the backlight or the main board that cause the damage to the power supply board and will damage the new power supply board the same way?
Hello all,
I bought and installed the replacement power supply board.
Now when I try to turn on the TV the audio start, but the screen is completely black…
I guess it could be the main board, the back light the LCD itself or a combination… Any idea how I could troubleshoot this?
Is it even worth to try to resuscitate this TV?
crwdns2934271:0crwdnd2934271:0 JSa1987 crwdne2934271:0
