The Lenovo G50-80 is an entry level personal laptop released by Lenovo in 2009. The laptop has a 15.6 in screen and uses an Intel GPU processor.
Why is my laptop not charging even after plugging in the charger?
I plug in my charger to the laptop but it doesn't charge. Even when I move the charge a little here and there, nothing happens. The indicator doesn't light up also. I don't know if something is wrong with the charger or the charging port.
Hi @sheikhbasit
Use a voltmeter to check if there's 20V DC at the output plug of the charger.
If the charger is OK then perhaps the DC In jack is faulty.
Here's the hardware maintenance manual for the laptop.
Go to p.58 to view the procedure to remove the DC In cable. When it is out you can test if the jack is OK by using an Ohmmeter to prove continuity between the input and the output of the jack. Alternatively, if you just disconnect the jack cable from the motherboard and connect the charger to the jack's input you can check for voltage between the red and black wires of the cable on the jack's output.
If the DC-In jack is faulty it cannot be repaired, it has to be replaced.
There are two DC-In jacks available for your model and they are slightly different to each other.
The part numbers are 90205112 & 90205113.
Search for images of each part online by using the part number only to verify which one is used in your laptop and then order the part from the supplier that you suits you best
Hi, Sheikh, would be best to write directly to them Lenovo Support. And use your warranty for repairs, opening the laptop etc, would not allow you to use your full warranty and get free or discount repairs.
If the warranty is still valid for it, better contact Lenovo support directly, so you can benefit from free repars
Sheikh Basit crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 191
