2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Why does my keyboard from ifixit not fit?
I ordered a 2012-2015 MacBook Pro 15” keyboard from ifixit but it doesn’t fit my 2015 MacBook Pro 15”. There’s a notch below the spacebar on MacBook’s the upper case that doesn’t match up with the notch below the spacebar on the keyboard.
Good morning,
Last i checked, it isn't technically possible to replace the "keyboard" (the actual key mechanism) on it's own without pulling a Hugh Jeffreys. If your replacing the top case however, then that should work.
Can you add a photo showing the clearance issue as, from looking up on the internet, i can't find any obtrusive notch on the keyboard
My bad, I’ve realized that the keyboard does fit. I’ve uploaded a photo as an answer. I thought the bit that juts out (circled in blue) goes around the the bit that’s circled in red.
Owen Smith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 52
