The Nokia C5-03 is a budget touchscreen smartphone, first released in December 2010.
internal RF port location
How can I find out the RF antenna port location inside the phone. I want to connect an external wired RF cable to that port for some testing purpose.
crwdns2889612:0crwdne2889612:0 -1
Thanks for your response.
Yes, I would like to use antenna module located on the phone, but how can I find it. Where is the antenna module in this picture?
Pull your module and use the copper contacts where the module connects to the logic board
Yes, I have taken out the module. But I see two RF ports on the PCB. In the Phone schematic these are numbered as X7001 and x7002. How to figureout whichone I should use to solder an external RF cable.
Alok Gaur, may be this will show what you are after. Otherwise, have you consider using the antenna module as a tracing point.
Alok Gaur crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,716
