Why noise is coming while driving from front suspension
While driving a car noise coming from suspension
There may be a problem with the front shock absorbers.
Try the following:
Park the car on level ground, switch off the engine and apply the handbrake.
Go to a front corner of the car (either side) and push down as hard as you can on the body of the car and then let go.
Do this three or four times in a row to set up a rocking motion in the car and then after the fourth push, stop pushing and check if the car returns to its normal position with maybe one little bounce and then stops (without you touching it) or continues to bounce up and down a few more times.
If it continues then there's a problem with the shock absorber on that side.
Do the same on the other side and check.
If there is a problem here's a video that may help if it is a leaking shock absorber. .
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 260
