How to remove water from screen?
My phone is not a waterproof. How to remove water from my phone.
My phone is automatically working
@prajyotkachave
If the phone got wet, see the answer below.
Hi @hsjangiana1323
If there's water in the screen then it cannot be fixed, it has to be replaced. There may be other problems with the phone as well due to the water ingress.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Here is a video that shows how to replace the screen that may help. Search online for GH81-18736A to find display suppliers that suit you best.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Hs_jangiana1323 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 400
