The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Is there a way to fix a slightly bend slider rail on the tablet?
So the switch I have got a bit of a dent in the plastic since it got hit, and it messed up the top position of the right slider rail for the joy-con so I can't insert it there anymore, is there a way to fix it to position or melt the metal since I've tried fixing it with some pliers which didn't work by the way, so there's a way I can re-insert the joy con again without sending it for repair?
Hi Deezero.
Unfortunately if bending it back into shape didn't work you will have to replace the rail.
the casing of the switch should be able to be bent back into shape.
you can get a new rail from Ifixit here
And a guide to replace it yourself can be found here.
Hope this helps
crwdns2886500:0Replace a broken or malfunctioning Joycon sensor rail on the right side of your Nintendo Switch console.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Nintendo Switch Right Joy-Con Sensor Rail
$14.99
Unfortunately this did not work for me(
deezero crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 298
