A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
nail polish remover in screen
i had spilled some nail polish remover that i believe it had acetone through the speaker and it entered the screen. the speaker went out for a couple of minutes but eventually started working again. will the acetone dry out of the screen? i have it tipped so the corner is on a towel and facing open towards a fan. also, if the speaker came back do i need to worry about it or anything else? all of the keys are working, just appears there is liquid under the screen
Nail polish remover is more than acetone! It has fillers. Think how a puddle of milk on the counter sits for awhile the water evaporates, but the non-water parts stay.
So while the acetone and water will evaporate. There is more happening here besides the solids left behind. The plastic parts within the display are likely damaged. Here we are talking about the defuser sheets and rear polarizer sheet which is glued to the back of the LCD panel. Take the time to review this MacBook Pro Retina Display Teardown while it’s an older system the display tech is the same!
This display is even harder to open up! I wouldn’t attempt it as your more likely cause more damage things.
So what to do to speed things up. I would use a hair dryer warming it up a bit. The trick is not to over heat things and you want to heat the metal not the glass and keep it warm for a few hours as you don’t want it to re-condense inside.
After a few days see if you can live with things, if not it’s time for a new display MacBook Pro 13" Function Keys Late 2016 Display Assembly Replacement consider your skills set and the costs before you head down this path. It’s not overly hard but these connections and exposed parts are fragile!
crwdns2886500:0MacBook Pro 15" Retina Display Mid 2012crwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0MacBook Pro 13" Function Keys Late 2016 Display Assemblycrwdne2886500:0
1 - 2 hours
kennedy moyer crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 185
