How do I deal with these buttons?
UPDATE: I’ve made it past the motherboard and got to the buttons area, which I’ve swapped out the silicone bit with. Unfortunately, it didn’t fix the original problem, which was the A button needed significantly more pressure than usual to register. I think I should either get the sticker that covers the buttons on the motherboard, which I’ve checked and can confirm looks fine for the most part, or jump the gun and get a new button motherboard.
It also seems that my L button has stopped working as well; pressing down on it regardless of pressure doesn’t input anything.
Any ideas?
@theg18747 Have you tried a screwdriver that's one size bigger?
crwdns2934271:0crwdnd2934271:0 Dany crwdne2934271:0
@dannish I have, but the problem there is that it has the same result. I’ve attempted using a #00 and #000 Phillips head screwdriver for all of the unproblematic screws, and got them out easy, but I can’t say the same for the remaining two.
crwdns2934271:0crwdnd2934271:0 Theg_ crwdne2934271:0
@theg18747 if you try a #0 does it slip?
@dannish The two #0 screwdrivers I’ve been using can just barely catch on to the motherboard screws, but the #00 one can do it more efficiently. I’ve tried to use the #0 on the more stubborn ones, but it’s only resulted in it bumping over.
@theg18747 yeah #0 is too big then. I would try a better quality screwdriver like a Wera, sometimes they can pull out screws other drivers can't.
I really would not recommend what the other guy said, lubricant residue on electronics is going to be hard to remove.
