The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
My phone is not charging
I am using Redmi Note 8 from last 6 months but from yesterday it is not charging Please give me a solution what can I do
@ronakswami You can try cleaning out the charge port with a toothpick or other non-metal tool for a start. Does the phone boot at all or its completely dead?
@ronakswami you have not told us what you have checked. You need to start with your charger. Make sure that it is working properly. Next check your charging cable. Try a different one to make sure it is okay. After that you want to check the charging port. Make sure that it is clean, with no bend or corroded pins. You can clean it with a few drops of isopropyl alcohol and some canned air.
If all of that is okay, you need to consider changing the battery. Then re-evaluate. If it is still not charging, it could be the charging port that has failed or your phone is having issues with the charging circuitry. That will require some board level repair.
Xiaomi Redmi Note 8 Battery Replacement and something like this video for the charging port. The charging board, which includes the charging port, is available at many sites. Just do an online search for a vendor that meets your requirements.
It's doesn't charge
@wilbroadkavula same as in the above answer.
Ronak Swami crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 8,011
