Why my wifi is showing no network
My wifi is showing no network found I checked it on internet but it has no software problem
@saiasissahoo Open Device Manager and look for your WiFi adapter under Network Adapters. Does it have a yellow exclamation mark?
If so, that is a driver error. The driver needs reinstalling. Right click and hit Uninstall. Then reboot the computer.
If that still doesn't work, you may have a failing network adapter. As a cheap fix, you can buy a small usb WiFi dongle and leave it in the laptop.
There can be many reasons why your WiFi is showing “No Network Found.” Here are some of the most common reasons:
  • The router is turned off or not connected to the internet. Check to make sure that the router is turned on and that it is connected to the internet. You can do this by checking the lights on the router or by logging into the router’s web interface.
  • The WiFi network is hidden. Some WiFi networks are hidden, which means that they do not broadcast their name. To connect to a hidden WiFi network, you will need to know the network name and password.
  • The WiFi network is out of range. If you are too far away from the router, you may not be able to connect to the WiFi network. Try moving closer to the router to see if that fixes the problem.
  • The WiFi adapter on your computer is not working properly. If your WiFi adapter is not working properly, you may not be able to connect to any WiFi networks. Try restarting your computer or updating your WiFi adapter drivers to see if that fixes the problem.
  • There is a problem with your computer’s network settings. If you have recently changed your computer’s network settings, you may need to reset them to their default settings.
  • There is a problem with your internet service provider. If your internet service provider is experiencing problems, you may not be able to connect to the internet. You can check the status of your internet service provider’s website or by contacting their customer service department.
If you have checked all of these things and you are still having problems connecting to your WiFi network, you may need to contact your internet service provider for help.
Here are some additional tips to help you troubleshoot WiFi problems:
  • Restart your router. This can often fix minor problems with the router.
  • Forget the WiFi network and then reconnect to it. This can sometimes fix problems with the connection between your computer and the router.
  • Update your WiFi adapter drivers. You can download the latest drivers from the manufacturer’s website.
  • Reset your WiFi adapter. This will erase all of the settings on your WiFi adapter and restore it to its default settings.
Sai asis Sahoo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 199
