The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
Rewiring my volume control?
I have an old ds that doesn't work any more and i was wondering if i could tahe the volume control out of it and use it in my mint tin amp if so how would i wire it
Can u post pictures of the wires in question? Both, if possible?
If you know how to use an ohm meter, you should be able to figure it out, However...
It is not as 'cool' but buying the right value (both resistance and power rating) is probably a better bet. For not much money you can get the right part with all the mounting hardware.
Give it a try. Take the potentiometer out of the DS carefully. It most likely will have three terminals. Connect your audio source to the right most terminal, connect the audio input to the mint tin amp to the wiper (the center terminal) and ground to the the left most terminal.
This is a fairly generic statement, assuming the pot in a DS looks like the kind in other toys. Basically you have a resistor with a sliding center tap. So you can use an ohm meter to determine which terminal is which. If the volume goes down when your expecting up, reverse the wires from left to right, leave the center tap the way it is.
I don't believe that you will have much success.
-Me-
joshua crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,444
